Date/Time: Fri, 07 Feb 2025 15:22:05 +0000
Extend to Future Intersection lines don't stop at intersection
View Count: 1855
[2022-04-11 15:19:35] |
User863830 - Posts: 23 |
Color Bar Based On Alert Condition study Based on Volume Point of Control for Bars study (VPOC) with Extend line to Future Intersection doesn't stop drawing at price intersection using Alert Condition of "5=5" Is there a way to fix this or possibly add "Extend to Future Intersection" feature to "Volume Point of Control for Bars study". |
[2022-04-11 15:32:27] |
Provide an image of the chart showing this issue, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Remove all studies from the chart except for that one. Additionally, provide that particular chart by following these instructions here: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-11 15:37:13
[2022-04-11 18:20:28] |
Attached is the chart
Attachment Deleted. Private File |
[2022-04-15 22:41:56] |
The problem is when you are basing the Color Bar study on another study, future intersection lines are going to be compared to that other study. Not to the price bars. You have the base the Color Bar Based on Alert Condition study on the main price graph. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-15 22:57:14
[2022-04-15 22:57:00] |
We will see how to improve the Color Bar Based on Alert Condition study to do what you want.
[2022-04-16 00:30:57] |
Or add the feature to the "Volume Point of Control for Bars" study. The "Numbers Bars" study has this ability... Highlight Point Of Control... Column 1 with Extension Line until Future Intersection It would be nice to have this valuable feature on the "Volume Point of Control for Bars" study also. |
[2022-04-20 12:32:35] |
We have implemented a solution to this and this will be out in the next release. The Color Bar Based on Alert Condition study has this new setting with its Output When Condition True Input: Study Subgraph Reference. When using this there is no need to directly base the Color bar Based on Alert Condition study on another study which is causing the problem in your case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-20 12:33:00
