Date/Time: Mon, 10 Mar 2025 20:39:30 +0000
boutons personnalisés
View Count: 495
[2022-04-11 14:13:32]
User914407 - Posts: 49
Bonjour,
J'ai créé un fichier Myfile.cht avec mes parametres mais quand je le charge tout est ok sauf les boutons que j'ai personnalisés qui ne sont pas là
Merci
[2022-04-11 17:04:57]
John - SC Support - Posts: 38547
From Google Translate:
I created a Myfile.cht file with my parameters but when I load it everything is ok except the buttons I customized which are not there
Control Bar Buttons are not saved with the Chartbook. They are saved in the Global Configuration file named Sierra4.config. Therefore, if you are wanting the same settings between instances of Sierra Chart, you would need to also copy that file.
Refer to the information in step #5 in this section for what is stored in each of the files in the Sierra Chart folder:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
