Date/Time: Mon, 10 Mar 2025 20:14:19 +0000
Flexible MAs not workiing with 2383 Update
View Count: 517
[2022-04-11 12:47:51] |
User696540 - Posts: 29 |
Hello, SC just did an update to 2383 and this error message is appearing for the Flexible MA study: "Failed to get the function address for scsf_MAs" Can you please fix this? Thanks |
[2022-04-11 13:29:34] |
This study has been removed. We had a quick look at the source code. You will want to add to the chart 2 Moving Averages of the type you require and set the Inputs as you require. Then follow the instructions here: Chart Studies: Filling the Area Between Two Study Subgraphs within Different Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
