Date/Time: Fri, 02 Oct 2026 09:59:48 +0000
from 2379 to 2382 : merge profile does not work anymore
View Count: 928
| [2022-04-11 12:19:19] |
| User877753 - Posts: 152 |
Something has changed with TPO profiles : I can't merge overnight sub sessions from TPO profiles with 2382 (I have been doing this for years until today). Thanks for your help. |
| [2022-04-11 13:25:31] |
We will check on this and resolve. Probably this issue arose, when we were correcting another problem. We apologize for this.
| [2022-04-12 07:13:57] |
| User00001 - Posts: 8 |
same issue on 2383 fwiw
| [2022-04-13 16:52:08] |
| alexvmit - Posts: 9 |
Thought it's just me, dealing with the same issues!
| [2022-04-13 17:14:45] |
We expect to have a new release out today to resolve this.
| [2022-04-14 15:28:04] |
Seems V2384 fixed it. Thanks.
