Date/Time: Mon, 10 Mar 2025 20:21:28 +0000
VisualCCompile.bat
View Count: 458
[2022-04-11 11:18:45] |
User921987 - Posts: 238 |
Is it possible to edit permanently the compiler options in VisualCCompile.bat ?
[2022-04-11 11:54:29] |
No because that file is overwritten just before it is run. You need to build your studies outside of Sierra Chart using Visual C++, to do anything custom not supported by Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-11 11:55:01
