Date/Time: Mon, 10 Mar 2025 20:32:56 +0000
New Instance charts
View Count: 923
[2022-04-11 08:06:08]
fuziam - Posts: 5
Hi there,
If i try to open my saved chartbooks on a new instance i can't find them, but i can in the instance where they've been created
could you help me to figure out please?
Regards
[2022-04-11 13:47:29]
So on the sub instance when you go to File >> Open Chartbook you do not see the Chartbooks there? If not then copy them from the main instance:
Using DTC Server for Data and Trading in Another Sierra Chart Instance: Copying Files Between Instances
Date Time Of Last Edit: 2022-04-11 13:47:43
