Date/Time: Mon, 10 Mar 2025 20:16:21 +0000
Drawing on detached window not working v2382
View Count: 570
[2022-04-11 05:40:41] |
User183843 - Posts: 12 |
Hi! After the latest update i have following issue: I am using a chartbook with 2 detached chart windows. To draw a rectangle on the detached window, I do following: - click on the detached window - select rectangle drawing tool on the tool bar of my main window - draw the rectangle on the chart This does not work anymore since the update. I can do drawings on all other charts of the chartbook as long as they are "attached". |
[2022-04-11 06:51:19] |
Go to the Tools menu on the ddetached chart window and make sure the Rectangle tool is selected. We do know what the problem is and this will be resolved in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
