Date/Time: Mon, 10 Mar 2025 20:36:50 +0000
Topstep/Rythmic Easy Solution
View Count: 658
[2022-04-10 23:44:53] |
User728373 - Posts: 9 |
Hello, I recently signed up for a Topstep combine. They initially tell you to connect to Rythmic on Sierra Chart. But I had all types of data gaps with Rythmic. After communicating with Topstep about this issue, I was directed to the Sierra Chart Easy Solution page. My understanding from reading the Easy Solution's page is that I should use the Denali realtime data feed, which I believe I am signed up for to connect to Rythmic through Teton for Topstep. Hopefully, I am understanding this correctly. I am not sure how to go about this. I do have a funded account with AMP Futures/AMP Global clearing. Would you be able to walk me through the steps necessary to get all of this set up? Thank you in advance, |
[2022-04-10 23:51:17] |
Because you have an account with AMP, you do not need to use that easy solution. It is not applicable in your case. The only other remaining thing you need to do is just activate the exchanges you need here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed After that re-download the data: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-11 00:14:16] |
I appreciate your help. I activated the CME Exchange. After I Re-download all the data, I do not need to make any data connection changes? It will automatically connect with the settings that Topstep gave me?
[2022-04-11 07:09:30] |
Top step trader uses Rithmic. Therefore, you need to follow through the instructions on this page here: Rithmic Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
