Date/Time: Sat, 19 Sep 2026 07:59:25 +0000
Add Horizontal Line (separator) between Region 1 and 2
View Count: 2657
[2022-04-10 19:50:42]
User600202 - Posts: 37
How do I add a horizontal line as a separator between Region 1 (e.g. OHLC bar chart) on top and Region 2 (a study like an RSI, etc.) on bottom?
I don't mean using "Tools | Horizontal Line" which is based on the scale, etc. Just a plain horizontal line to clearly mark top Region (1) from bottom Region (2)? It is really only for visual.
I can see that the regions are separated right now by a break in the vertical grid line which shows a small break (space) between regions but I'd like a border/line there.
Thanks.
[2022-04-10 20:39:47]
caligola - Posts: 116
Chart Settings --> [Grid] --> Display Region Dividing Lines --> Yes
Chart Settings: Display Region Dividing Lines (Chart >> Chart Settings >> Grid menu)
Date Time Of Last Edit: 2022-04-10 20:40:25
[2022-04-10 22:46:42]
Yes post #2 is correct.
[2022-04-11 02:17:01]
Perfect, exactly what I wanted, thanks.
