Date/Time: Mon, 10 Mar 2025 20:15:04 +0000
Unable to condense candles to see more
View Count: 464
[2022-04-10 19:46:53] |
12VMan - Posts: 45 |
I have 60 days on this chart, but I am not able to drag the x-axis to collapse the price action (i.e. pull in more days into the visible view). Lock fill space is not enabled and Interactive Scale Range is on. What am I missing?
[2022-04-10 23:45:36] |
Once the bar spacing reaches 0 it is not possible to compress the chart bars further without increasing the chart bar time period.: Changing Chart Bars Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
