Date/Time: Mon, 10 Mar 2025 19:28:33 +0000
DENALI LIVE OR NOT???
View Count: 462
[2022-04-10 18:38:15] |
User882361 - Posts: 5 |
Hi there, I am a bit confused here..... in the $36 I am paying is only for SC usage... so if I want Denali with Teton routing I need to purchase 'Live' Denali Data Feed on top of that? if yes please can U give the link where/what I need to pay please... ( I have and EdgeClear live acc.... so I can connect that one... ) best regards Robert Happ |
![]() Attachment Deleted. |
[2022-04-10 21:05:41] |
You need to follow the instructions here to connect to the Teton Order Routing Service: Sierra Chart Teton Futures Order Routing: Setup Instructions And then you need to activate the exchange that you require here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed This is all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-10 21:06:02
