Date/Time: Mon, 10 Mar 2025 19:26:23 +0000
Replay Mode Stops Working After Specific Date
View Count: 473
[2022-04-10 00:53:45]
User897692 - Posts: 9
When using replay mode and setting the start date to 01/5/2022 or any date thereafter, the charts do not play in real time but will only print a 1 minute candle every minute. When replaying dates prior to 1/5/2022 the replay happens in real time. I'm not sure how to show this without a video but I still attached a screenshot in case it might be of any use.
Thank you
imagesc_replay.png / V - Attached On 2022-04-10 00:52:22 UTC - Size: 107.48 KB - 138 views
[2022-04-10 22:48:14]
We see you are using CQG data. For complete tick by tick data and data for expired futures contracts you need to use one of these two services:
Sierra Chart Historical Data Service
Denali Exchange Data Feed
At this time it is easiest to install another installation of Sierra Chart and use the Sierra Chart Historical Data Service to do your replays. Do not use CQG data.
Or you can use the Denali Exchange Data Feed.
Date Time Of Last Edit: 2022-04-10 22:49:54
