Date/Time: Mon, 10 Mar 2025 19:30:38 +0000
I am having trouble setting up Denali Exchange Data Feed
View Count: 433
[2022-04-08 18:05:50] |
User733470 - Posts: 1 |
I am having trouble setting up the data feed. There's something that I'm just not getting right. Can you help me set this up?
[2022-04-08 18:58:28] |
John - SC Support - Posts: 38547 |
If you are wanting data from the CME Group, then you will follow these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you are wanting data from EUREX, CFE, or NASDAQ TotalView, then follow these instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
