Date/Time: Fri, 07 Feb 2025 14:55:37 +0000
Pullback ask bid difference divergence
View Count: 575
[2022-04-08 17:51:01]
User482635 - Posts: 6
Is there a way that i can mark candles when the low pullback ask/bid difference is negative on green candles or the high pullback ask bid difference is positive on red candles?
[2022-04-08 18:56:11]
John - SC Support - Posts: 37808
This can be done. You would need to use the Numbers Bars Calculated Values study to access the High Pullback Ask Volume and Bid Volume Difference and the Low Pullback Ask Volume and Bid Volume Difference subgraphs. Refer to the following:
Numbers Bars: Displaying Numeric Information Below Numbers Bars
Then you would use the Color Bar Based on Alert Condition to get the marking that you want by creating the alert using the above information with the bar information. Refer to the following:
