Date/Time: Tue, 26 Nov 2024 09:51:02 +0000
gene sheldon
View Count: 1053
[2014-04-23 20:08:02]
User72965 - Posts: 115
Market Depth not populating
Also can not get DOM Graph on charts ??
Dom <> Get the bars > No volume #'s %'s ect.
Just Bars. Would like #'s. too.
I think something not connected ??? Do have DTN Data working.
All charts getting populated with data. No DOM Graph though .
Tried to go back to 1097 version ?? All ok till The finish.
Then Aborts ???? So can't go back to 1097 ( DOM Graph works there.
Problem here somewhere ???
Thx Gene . Is there a trial on Sierra Data Feed ???
[2014-04-24 18:56:57]
Please post an image of a chart showing what you see for the DOM graph. Here are the instructions:
https://www.sierrachart.com/index.php?l=PostingInformation.php#Image
The Sierra Chart Exchange Data Feed does not have a trial. It is a good data feed though. If you subscribe to the data feed now, you will only be billed a portion of the 35 USD per month. It is prorated. So it is going to be less than 10 USD until the end of the month.
Date Time Of Last Edit: 2014-04-24 18:57:31
