Date/Time: Mon, 10 Mar 2025 19:03:54 +0000
No real time stocks data
View Count: 547
[2022-04-08 14:32:22]
User999647 - Posts: 38
Hi I am on 10 - standard + Daneli, also it was confirmed that I have activated NYSDAQ as well.
However, I still do not see realtime stocks data - No "M" next to the ticker. Any thoughts?
[2022-04-08 16:00:38]
John - SC Support - Posts: 38547
Make sure you are entering the stock symbols with the suffix "-NQTV". This is necessary in order to differentiate the data from the Sierra Chart Exchange Data Feed.
For example, to get the data for AAPL from the NASDAQ TotalView exchange, you need to enter AAPL-NQTV
[2022-04-09 07:49:00]
Hi, thanks for the advice. However, I tried AAPL-NQTV, there was no reaction - turned white and did not download any data. Previously with AAPL it downloaded data even though with long periods of missing data, with AAPL-NQTV no reaction at all. Any suggestions? Thanks
[2022-04-09 09:31:02]
First you must update to the current version. This is mandatory to resolve the issue. Instructions:
If you have any missing data in a chart, refer to:
After the update, for your -NQTV charts, follow the instructions below:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
Date Time Of Last Edit: 2022-04-09 09:31:22
