Date/Time: Mon, 10 Mar 2025 20:32:54 +0000
REQUEST: Chartbook Cycle Mode
View Count: 461
[2022-04-08 13:28:43]
ycomp - Posts: 321
It would be great to have a feature that could be toggled by Hotkey. Once pressed the next chartbook is displayed, then after a certain delay, then next, after the delay again, the next chartbook. Continually cycling through them until the toggle key is pressed again.
This would be great for sitting back and watching what is happening on the market. The delay time in seconds should be configurable as well. Please consider this, thanks.
[2022-04-08 14:07:46]
You can do this using ACSIL. You can start by using this function:
sc.OpenChartbook (This will make visible the Chartbook if it is already open)
We can also add a function to go to the next or previous Chartbook.
Date Time Of Last Edit: 2022-04-08 14:08:09
[2022-04-13 07:59:01]
ycomp - Posts: 321
if these next/previous functions are added, where should the ACSIL code be run from? create another chartbook with a blank chart and just put the study on there to call the next/previous chartbook functions?
