Date/Time: Wed, 27 Nov 2024 21:25:30 +0000
different color for the scale
View Count: 761
[2022-04-08 05:49:52] |
user8888 - Posts: 159 |
Hello, is it possible to have a different color in the scale background than the chart background? Thank you |
[2022-04-08 14:21:55] |
John - SC Support - Posts: 36349 |
There is not a separate control for the Scales background. It just uses the main Background setting.
[2022-04-08 14:40:10] |
Thank you John, I thought so. Would it be too much to ask for it? different color for the background of the price scale and the background of the time scale? just those two things or at least one of them, might improve the look of the charts a lot ... In any case, Thank you ! |
[2022-04-08 14:47:38] |
Tony - Posts: 521 |
user8888, Could you give me some details (examples) with numbers? If there is an easy solution, I will send you a custom study to achieve that. It might be a bit too specific for Sierra team to spend time on it. Date Time Of Last Edit: 2022-04-08 14:50:07
[2022-04-08 16:03:55] |
We have set this as a Feature Request. We do not know when or if we will get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-08 16:07:57] |
Hello Tony, Attached is an example of the same chart with SC and with other platform (a crappy one in comparisson with our beloved Sierra Chart). Since the SC team have been working, in the last year or so, so much, in improvements in the graphics section (among a ton of other things), I'm just telling them about the possibility of adding a couple more of settings , background color for the price scale and background color for the time scale or time line. Background color for the Chart header might good aswell, but ... I'm not asking that much. It depends on their code how complicated or time consuming enabling this could be. I don't know. They have the answer. Might be relatively simple .... it depends. In my humble opinion, not only improves the looks but also helps, a bit, in focusing better the chart since it frames it even more. Anyway Thank you for your offering ! |
Attachment Deleted. ES_F-2022-04-08-02.PNG / V - Attached On 2022-04-08 16:07:35 UTC - Size: 67.7 KB - 173 views ES_F-2022-04-08-01.PNG / V - Attached On 2022-04-08 16:07:45 UTC - Size: 161.49 KB - 170 views |
[2022-04-08 16:47:13] |
Tony - Posts: 521 |
user8888, Oh, I get it now, sorry, I misunderstood your question, my bad. I am glad John set this as a Feature Request, it can not be done by a custom study. Looked your screenshot, you are right, it does look much better when time and value scales have different colors than chart background color. Cheers, |
[2022-08-29 17:15:11] |
Hello SC Support, How is this going? Thank you |
