Date/Time: Mon, 25 Nov 2024 20:33:11 +0000
Help copying LVN and HVN from 30 min Volume Profile chart to 15 min Candlestick charts
View Count: 960
[2022-04-08 00:03:17]
User275302 - Posts: 52
Hello, I'd like to have the LVN and HVN lines from my Volume Profile on my 30 minute chart copied automatically to a 15 minute candlestick chart I use. I know hot to have the basic 'Tool' Drawings copied by listing the chart number in Advanced Settings 2, but that doesn't seem to work for the LVN and HVN. Any help will be much appreciated. Thanks, James
[2022-04-08 13:54:37]
John - SC Support - Posts: 36278
We assume you are using the Peaks and Valleys to get the LVN and HVN information. As such, there is not a way to copy these to another chart, as the information is only stored internally and is not made available to other studies.
[2024-02-02 15:22:05]
cesium - Posts: 85
Since some time has elapsed since this thread, is there a way using the study subgraphs reference study in combination with the Subgraphs Overlay to achieve this?
Thank you
[2024-02-02 17:40:02]
There have not been any changes that make this information available.
