Date/Time: Mon, 10 Mar 2025 19:09:06 +0000
order remains active
View Count: 442
[2022-04-07 20:00:51]
User504309 - Posts: 11
is there a way or setting to keep opened bracket order ( s/l and t/p ) active after sc platform and internet connection closed?
[2022-04-07 20:42:40]
John - SC Support - Posts: 38547
Our servers indicate that you are using CQG for your trading. As such, the OCO orders are handled through the CQG server, so you would not need to keep Sierra Chart open. The only time this will not be the case is if you are using a more complex order type, such as "Market if Touched", or one of the "Chase" types, or one of the specific "Client" orders.
Refer to the information here regarding CQG server support for OCO and Bracket orders:
CQG Trading Platform Service: What is Included
And refer to the following for the various Order Types:
Order Types
[2022-04-07 21:31:38]
Sierra_Chart Engineering - Posts: 18732
Make sure you fully understand this functionality. Refer to:
Attached Orders: General Management of Attached Orders
And we absolutely recommend moving from CQG to Teton, if you are trading CME Group:
Date Time Of Last Edit: 2022-04-07 21:32:08
