Date/Time: Tue, 26 Nov 2024 06:58:36 +0000
AMP/TTNet and $VIX historical
View Count: 1407
[2014-04-23 17:34:03] |
User025822 - Posts: 35 |
I am using Sierracharts with AMP/TTNet and was wondering is its possible to have the $VIX historical chart. I tried opening an historical chart of it but got error message that could not download data and that file was empty. thank you |
[2014-04-23 17:50:06] |
If you want a Historical Daily chart for that symbol, then you need to have a direct account: https://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
