Date/Time: Mon, 10 Mar 2025 19:19:05 +0000
setting up subscription
View Count: 460
[2022-04-07 17:22:21] |
s&ptrader - Posts: 1 |
which subscription package do i need to start trading with cqg and amp futures
[2022-04-07 18:12:56] |
John - SC Support - Posts: 38547 |
Right now any package will work. If you are getting data from CQG, then either package 3 or 5. Refer to the differences in the packages here: Description of Service Packages and Pricing: Packages To setup your connection to CQG, follow these instructions: CQG Trading Platform Service: Setup Instructions If you are going to get data from our Denali Exchange Data Feed, then you would need to be on Package 10, 11 or 12. You will find the differences in the packages on the same page as above. To setup the Denali Exchange Data Feed, follow these instructions for the CME Group data: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you are wanting data for EUREX, CFE, or NASDAQ TotalView, then you would need the following instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
