Date/Time: Mon, 10 Mar 2025 19:14:48 +0000
Delayed Data
View Count: 467
[2022-04-07 17:18:25] |
arturkeil2806 - Posts: 3 |
Hello, when I connect with "SC Data-All Services" i got 10min delayed data. When I then connect with CQG i got no data at all, symbols can't be found. Usually I connect once a week with CQG to avoid get delayed data, but now it's not working any more. AMP confirm that everything is good on their side. Thanks and best regards. |
[2022-04-07 18:23:15] |
John - SC Support - Posts: 38547 |
You do not have any exchanges active on the Denali Exchange Data Feed. You did have an exchange active, but it failed to renew on March 1, 2022. You can reactivate the exchange(s) you want from this page: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
