Date/Time: Mon, 10 Mar 2025 19:01:00 +0000
chart not loading
View Count: 437
[2022-04-07 17:17:44]
Sergei Belov - Posts: 3
I received *.CHT file with chart and study from a very experienced Sierra Chart user co-worker but the chart comes empty.
What should I do to load the chart?
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=63198
[2022-04-07 18:06:14]
John - SC Support - Posts: 38547
Most likely the person you received the chart from is not using the same trading service you are using, therefore the symbols would be different. To update the symbols, open the Chartbook and select Edit >> Translate Symbols to Current Service.
