Date/Time: Mon, 10 Mar 2025 19:01:28 +0000
Control Bar buttons issue
View Count: 669
[2022-04-07 15:05:54]
User723043 - Posts: 11
Hi all,
after installing version 2379, if I choose the buttons of the tools saved in the Control Bar (below the Menu Bar on the main window of Sierra) to draw for example a line in a graph, they no longer work in detached graphs but they work only in attached ones. Is it a deliberate change or do I've to change something in the settings? Thank you.
[2022-04-07 15:27:12]
John - SC Support - Posts: 38547
We do see an issue with the setting for Tools >> Tool Settings >> General >> Use Common Drawing Tool for Charts. It appears that when this is set to Yes it is not working properly in the latest release. We will check into this.
[2022-04-08 08:51:31]
User93464 - Posts: 52
I seem to have a related issue. When selecting a drawing tool for a chart in a chartbook of 4 charts, SC no longer applies the drawing toll across all charts in the chartbook, only to a single chart. This means that all four charts in the chartbook could have a different drawing tool active in play, causing some charts to behave oddly. So now I have to exit the drawing tool for each chart individually
[2022-04-08 15:16:02]
We are looking into why the option for Use Common Drawing Tool for Charts is not working correctly in the latest release.
[2022-04-10 23:21:34]
Sierra_Chart Engineering - Posts: 18732
This will be solved in the next release.
