Date/Time: Wed, 09 Sep 2026 10:36:35 +0000
Chart Drawings Alert
View Count: 708
[2022-04-07 14:31:23]
User377189 - Posts: 216
I have set up chart drawing alerts but i am wondering if i can have same saved chart drawing in chart drawing properties have different alert sound for different chartbooks?
e.g. I have saved a template which includes color/thickness and alert for chart drawing - Line for ES CHARTBOOK
Keeping the same template for the Line i would just like to change the alert it sounds for a different chartbook, say AUD Chartbook
How can i set this up?
[2022-04-07 15:06:57]
John - SC Support - Posts: 47806
You would either need to change the Alert manually when you are using it in the AUD chartbook, or you could setup a different configuration with just the change in the Alert number and then be sure to use that configuration in the AUD chartbook.
Refer to the following regarding saving configurations:
Chart Drawing Tools: Drawing Tool Configuration
