Date/Time: Mon, 10 Mar 2025 19:36:34 +0000
Chart Region (Chart >> Chart Settings >> Advanced Settings menu)
View Count: 622
[2022-04-07 14:16:08]
Technical - Posts: 158
Chart Settings: Chart Region (List) (Chart >> Chart Settings >> Regions >> Chart Region menu)
I am trying to set the chart update interval in the latest version. I do not see Advanced Settings in the new menu.
Has this diminished into a global setting only, no longer available per chart?
[2022-04-07 15:02:41]
John - SC Support - Posts: 38547
It is the first item in the list under the Display tab.
[2022-04-07 17:47:20]
Pardon me if I am missing it but I don't see a display tab under Chart >> Chart Settings.
See enclosed.
imagedisplay tab.png / V - Attached On 2022-04-07 17:46:47 UTC - Size: 47.36 KB - 141 views
[2022-04-07 19:40:11]
You need to update to see that tab. Instructions to update:
