Date/Time: Mon, 10 Mar 2025 17:27:34 +0000
Color Labels for alert in alert manager
View Count: 444
[2022-04-07 06:31:34] |
User361939 - Posts: 167 |
Hello, Is it possible to add color labels for specific alert appearing in alert manager? This is useful if we have several types of alert and if i can label them with color i would now miss the most important ones. Best Regards |
[2022-04-07 12:11:36] |
No, this is not supported.
[2022-04-07 13:15:47] |
Would you consider adding this? Best Regards |
