Date/Time: Mon, 10 Mar 2025 17:09:14 +0000
How to get SC to put each detached chart on the taskbar
View Count: 478
[2022-04-07 00:23:57] |
User357195 - Posts: 123 |
SC, How do I get SC to display an icon for each detached chart onto the taskbar? Right now Windows just puts each detached chart all together under the Sierra Chart icon that is on my taskbar. I think Sierra Charts are the best. Thanks in advance. Date Time Of Last Edit: 2022-04-07 00:28:45
[2022-04-07 13:45:57] |
This is not within our control, at least not anything we would be trying to solve.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-07 13:46:08
[2022-04-07 13:47:32] |
John - SC Support - Posts: 38541 |
This is a Windows setting, not Sierra Chart. On Windows 10 go to Settings and search for "Taskbar Settings" and select the "Taskbar Settings" option. Find the option for "Combine Taskbar Buttons and set to what you want (personally, I prefer "Never"). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
