Date/Time: Mon, 10 Mar 2025 17:09:48 +0000
[Locked] - Delays/Freezing with Start/Exit Sierra Chart, High Memory Usage,Uploading SC Order Fills
View Count: 1233
[2022-04-06 21:23:19]
Refer to the notes for version 2379 here:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2379
[2022-04-07 11:08:12]
To ensure you are not affected by this issue, follow the instructions below:
1. Set Global Settings >> General Trade Settings >> Send Order Fills to SC Web Server to No.
This option has no useful purpose any longer and it should not be used.
2. Exit from Sierra Chart
3. Go to the /TradeActivityLogs subfolder in your Sierra Chart installation folder (Usually C:\SierraChart).
4. If you see a OrderFillsToSend.data file, then delete it. This may actually be a large file. if this file is a very large file, this is the cause of the issue.
5. Run Sierra Chart. This is all.
Date Time Of Last Edit: 2022-04-07 11:08:48
