Date/Time: Mon, 17 Mar 2025 12:12:50 +0000
[Programming Help] - GetUserDrawnDrawingsCount() functionailty?
View Count: 1202
[2022-04-06 19:34:30]
User404097 - Posts: 10
I need to loop through my User Drawn Drawings but have no way of accessing the count of the total user drawn drawings for the terminating condition in my loop. There is a GetACSDrawingsCount() function but I can not find any documentation relating to user drawn drawings, specifically their count.
I am curious if I am missing something or if this functionality is not implemented.
Any help would be greatly appreciated.
Date Time Of Last Edit: 2022-04-06 19:38:49
[2022-04-06 21:52:46]
We will need to add a new function for this. We will do that.
[2022-04-20 18:44:20]
Thank you. Is there an update on when this will be completed? I appreciate the support.
[2022-04-20 22:49:44]
JohnR - User831573 - Posts: 320
Another request in the same area, would be to have another property added to the drawing structure(s). It would be Group_Num. This would allow me and others to create our own tools that have multiple lines/objects as part of it and then be able to maintain it as the user modifies it.
JohnR
[2022-09-06 23:14:20]
Is there any update on whether or not the SC team is working on this? Would be extremely helpful for our team. Thank you so much.
[2022-09-07 06:35:42]
User907968 - Posts: 838
Version 2380 has function added but not yet in documentation, you can see it yourself in sierrachart.h
sc.GetUserDrawnDrawingsCount(int ChartNumber, int ExcludeOtherStudyInstances);
Date Time Of Last Edit: 2022-09-07 06:35:52
