Date/Time: Fri, 28 Feb 2025 01:57:11 +0000
Bug report: Order fill markers disappearing on charts
View Count: 970
[2014-04-23 15:41:56] |
DarthSidious - Posts: 63 |
SC v 1110, TT feed, product tested: YM-201406 Steps: 1) Start SC. Be in live trading mode. Observation: all previous order fill markers visible on chart 2) Place live trade. Close trade. Observation: all order fill markers visible on chart 3) Go to SIM mode. Observation: all order fill markers vanish on chart (this is as designed. Now we are in SIM mode, and should not see live order fills) 4) Open & close a trade in SIM mode. Observation: all order fill markers visible on chart (SIM ones) 5) Execute "Clean trade simulation orders and data". Observation: all order fill markers gone 6) Go to Live mode. Observation: all order fill markers are no longer visible on chart Workaround: Restart SC. Observation: all order fill markers visible on chart |
[2014-04-23 16:45:36] |
tomas262 - Posts: 145 |
Had similar problem ... when started SC in SIM and then changed to LIVE I couldn't see live open positions ... workaround was to restart SC to see them again
Date Time Of Last Edit: 2014-04-23 16:46:18
[2014-04-23 17:03:58] |
Please test Sierra Chart 1126 and see if you notice this problem.
[2014-04-23 19:41:58] |
Tested with 1126, and the problem is not present any more. Thanks.
