Date/Time: Mon, 10 Mar 2025 17:19:27 +0000
BUG: Invisible S when S is used as a Keyboard Shortcut and you try to enter the Symbol
View Count: 433
[2022-04-06 16:14:31] |
ycomp - Posts: 321 |
1) Set up keyboard shortcuts 'S' for Sell Market Order 2) Open Chart Settings Dialog 3) Starting typing GBPUSD... it will look like GBPU... S will never appear... and you can see market orders get opened on the chart v2376 Date Time Of Last Edit: 2022-04-06 16:14:47
[2022-04-06 16:43:11] |
John - SC Support - Posts: 38542 |
This has been fixed in a newer release. Please update to the latest Pre-Release to ensure you have the fix. Follow these instructions to update: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
