Date/Time: Sat, 19 Sep 2026 04:15:35 +0000
How to chose what is displayed in the top line on a chart and how to fix the date and time
View Count: 849
| [2022-04-06 16:05:14] |
| User357195 - Posts: 204 |
SC, 1. How do I chose what is displayed in the top part of a chart, like right now it shows the symbol but it is also showing O H L C BxA size and etc? 2. How do I remove day from the bottom of my charts. I want to keep the date and time but remove the day name....ie, keep 22-04-06 and the time 11:27:42 but get rid of the day name...like Wed or Thu or Fri, and etc. See the attached chart of a visual of my questions. https://www.sierrachart.com/image.php?Image=1649261008934.png I think Sierra Charts are the best. Thanks in advance. |
| [2022-04-06 16:41:58] |
| John - SC Support - Posts: 47939 |
1. Refer to the following: Working With Charts: Region Data Line / Chart Header 2. Refer to the following: Chart Drawing Tools: Day of Week (Tool Settings >> Chart Values >> Date-Time Label Options for Intraday Charts) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
