Date/Time: Mon, 10 Mar 2025 17:09:21 +0000
deleting studies from analysis section
View Count: 965
[2022-04-06 16:03:13] |
Steve Leon - Posts: 312 |
how can i easily delete studies in the analysis section that i am no longer using I guess some would be custom studies and others that i created as templates when setting up studies Thank you Steven Leon |
[2022-04-06 16:38:07] |
John - SC Support - Posts: 38541 |
Refer to the following: Chart Studies: Remove (Analysis >> Studies) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-06 16:39:44] |
ForgivingComputers.com - Posts: 1021 |
If you are referring to the list of Study Collections in the Analysis menu, and not actual studies, delete the files in the c:\SierraChart\Data folder with the extension "StdyCollct".
Date Time Of Last Edit: 2022-04-06 16:41:54
