Date/Time: Mon, 10 Mar 2025 17:04:47 +0000
Chart data setting is missing in charts settings
View Count: 470
[2022-04-06 12:49:27] |
User482635 - Posts: 6 |
Im trying to get to historical pullback data in the chart data settings but im missing the chart data tab, how do i get this option?
![]() Attachment Deleted. |
[2022-04-06 13:04:40] |
Update to version 2378. Instructions: Software Download: Fast Update You will find the setting on the Chart Data tab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-06 13:04:45
[2022-04-06 13:46:54] |
I keep getting a failed to create folder error so then nothing works after that. Says access is denied
[2022-04-06 14:55:24] |
John - SC Support - Posts: 38541 |
Refer to the following: Software Download: Resolving 'Access is Denied' Errors For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
