Date/Time: Mon, 10 Mar 2025 22:29:08 +0000
DTC Client for Denali and/or Teton services
View Count: 647
[2022-04-06 10:33:37] |
User921987 - Posts: 238 |
Can a DTC client application with proper credentials connect to the Teton and/or Denali services without a running instance of SierraChart ?
[2022-04-06 11:26:55] |
Not for market data. For order routing, yes.
[2022-04-14 13:45:02] |
I read from your web page that the order execution is around 500us in your Aurora located server (client latency excluded). Is the Denali datafeed colocated in Aurora too ? What kind of latencies it does ? |
[2022-04-14 14:44:29] |
The market data has significantly higher latency. That can be in the range of 5 to 20 ms. It is very difficult dealing with market data. Especially when providing it to a large number of users and across the the global Internet. And yes, the market data does come out of Aurora. But not exclusively. It is also distributed, from the Chicago Equinix Cermak data center and also at the CBOT data center. If you have need for very low latency market data we can put you in contact with a firm who can help with that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-14 14:47:14
[2022-04-14 17:25:38] |
Thank you very much for the information. I will return to you later in this matter.
