Date/Time: Mon, 10 Mar 2025 17:17:11 +0000
DENALI
View Count: 441
[2022-04-05 19:26:00] |
User952312 - Posts: 1 |
Hi, i would like to know if everything is in working order so that i can trade with the denali flow in real best regards |
[2022-04-05 23:34:28] |
John - SC Support - Posts: 38542 |
Everything on your account looks good. Just make sure you are getting the real-time data and that you have the [M] showing after the symbol in the Chart Header to let you know you are getting the data from us. Refer to the following: Chart Data and Chart Data Files: The Meaning of the [M] Designation after a Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
