Date/Time: Mon, 10 Mar 2025 17:19:38 +0000
Using jigsaw with seirra chart for teton order routing
View Count: 872
[2022-04-05 18:26:08] |
User887126 - Posts: 84 |
Hi, I looked through the site and could not find clear answer to my question. I want to be able to place an order through jigsaw DOM and use teton order routing. I am planning to use stage 5 as my broker and sierra chart as my analysis/charting tools. is this possible and how much will it cost? I am currently using tradovate/jigsaw. Thank you in advance |
[2022-04-05 23:16:49] |
John - SC Support - Posts: 38542 |
The Teton Order Routing Service only works with the Sierra Chart software. You can not use Jigsaw to place an order to the Teton Order Routing.
