Date/Time: Mon, 10 Mar 2025 17:11:59 +0000
real time data requesr for two computers
View Count: 424
[2022-04-05 16:05:31] |
Rogar - Posts: 1 |
I have loaded Sierra Charts on two different computers and need real time feed for both via Denali feed. I also have a live trading account with AMP futures although it appears that you are not yet affiliated with AMP. I am a non professional trader. Please let me know what I need to do to get both running real time. Right now, my first computer is on real tiem and the second one is delayed data. thanks!
[2022-04-05 16:29:24] |
John - SC Support - Posts: 38541 |
You have not fully setup your Denali Exchange Data Feed yet. First, you need to activate the exchanges for which you want real-time data at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges Second, you need to connect your Sierra Chart software to your AMP account. Typically AMP sets up Sierra Chart users with CQG for order routing. If this is your situation, then follow these instructions to make this connection: CQG Trading Platform Service: Setup Instructions Finally, you will need to follow the instructions at the following link to allow for 2 computers to access the data at the same time: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
