Date/Time: Fri, 11 Sep 2026 12:06:16 +0000
Data Feed isn't coming in
View Count: 734
| [2022-04-05 13:50:02] |
| cyclistbw - Posts: 11 |
I have done a roll over on my account and just updated to get live data however I have to manually update it by disconnecting and then reconnecting my data feed. I must have missed checking something that says live data continuous or something?
| [2022-04-05 14:27:34] |
| John - SC Support - Posts: 47841 |
What is one symbol for which you are having an issue? And then get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
