Date/Time: Mon, 10 Mar 2025 17:20:35 +0000
VWAP for bar
View Count: 685
[2022-04-05 11:34:56] |
User138457 - Posts: 38 |
Hi, I couldn't find anything in the forum: Is there a way to show the vwap for each bar? I'm using range bars so I can not "work around" with a "fixed time" setting tia |
[2022-04-05 14:20:24] |
John - SC Support - Posts: 38542 |
Use the Volume Weighted Average Price - Rolling study and set the following Inputs: - Base on Underlying Data: Yes - Time Period Type: Bars - Time Period Length: 1 Set the other Inputs as required. Refer to the following for this study: Volume Weighted Average Price (VWAP) - Rolling with Standard Deviation Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-06 08:43:01] |
thanks! I already had tried it but always messed it up. The "base on underlying" was the deciding issue. I prob. misunderstood the description in that reagards. |
