Date/Time: Mon, 10 Mar 2025 17:17:33 +0000
Order Allocation to Trade Accounts ignoring order confirmation
View Count: 564
[2022-04-05 08:57:23] |
User898094 - Posts: 19 |
When using the order allocation to trade accounts feature, the order confirmation window pops up for new orders and flattening. Not appearing for modification of orders.
[2022-04-05 18:53:13] |
We cannot reproduce this problem. Make sure Order Modifications are enabled: Basic Trading and the Trade Window: Main/C >> Menu > > Confirmations >> Confirm Order Modifications (chart specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-05 18:53:20
[2022-04-06 00:57:52] |
Order modifications is enabled. The issue is there, as soon as I turn off order allocation, no confirmations for any order types. Order allocation on = confirmations. Any how, I've found a workaround, Chart Trade Settings > General > Confirmations > Disable Order Confirmations - Global = Yes |
[2022-04-06 14:52:04] |
Sierra_Chart Engineering - Posts: 18732 |
We are not able to reproduce any kind of issue like this at all. The confirmations all work properly. The behavior of this functionality is very stable.
