Date/Time: Tue, 26 Nov 2024 06:49:31 +0000
Green/red dot on right/left of footprint if green/red text/imbalance
View Count: 1529
[2014-04-23 13:28:34] |
Dom7364 - Posts: 257 |
Is there a study tgat would allow to display a coloured dot for example, next to a level on the Footprint? Perhaps is this in fact a visual alert, I am not sure, but the idea would be to display a green dot or red dot at the left or right of the footprint, when there is a volume imbalance displayed, i.e, when text is coloured either green or red according to the defined Threshold..? Thanks |
[2014-04-23 17:08:10] |
The usual way to do this is to configure the Numbers Bars color settings to visually indicate this condition. All of the color settings can be changed. You can use a neutral color for when this condition does not exist and whatever color you want for when the condition does exist. Refer to: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#ColorSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-23 17:09:08
[2014-04-23 17:13:58] |
Sure, thanks. it was just so that when you highlight levels of interests, you don't need to look at the actual number. More visual in a way.
