Date/Time: Fri, 13 Nov 2026 17:31:39 +0000
How to Remove Bars Overlaying TPO Chart?
View Count: 901
[2022-04-04 20:43:17]
User272662 - Posts: 9
Hello!
I duplicated this TPO chart from an ES chartbook and changed the symbol to NQ. After the data loaded the chart has bars over some of the TPO sessions and I cannot figure out how to remove them.
How can I resolve this?
Thank you!
imageTPObars.png / V - Attached On 2022-04-04 20:42:52 UTC - Size: 677.22 KB - 332 views
[2022-04-04 21:47:54]
John - SC Support - Posts: 48526
There must be a study that is causing that to occur. Go through the studies that are on that chart and remove them (or hide them) one by one until you find the one that caused the issue.
