Date/Time: Mon, 10 Mar 2025 16:30:18 +0000
Session Time for Futures (ES_F and NQ_F)
View Count: 424
[2022-04-04 17:23:19] |
User607231 - Posts: 5 |
What is the time zone that the session time needs to be in? Say, I'm from California, should I have the start at 15:00:00 (3pm PST) and ends at 14:00:00 (2pm PST)? Thank you. |
[2022-04-04 17:35:35] |
John - SC Support - Posts: 38533 |
It is really your choice as to what time zone you want to use. You just want to be sure you use a time zone that makes the same changes for daylight saving time as the exchange. Refer to the information here: Time Zone Setting: Resolving Differences with the Transition To/From Daylight Savings Time in Different Time Zones For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-04 17:35:46
