Date/Time: Tue, 26 Nov 2024 04:46:55 +0000
Connection Error: No trade accounts assigned
View Count: 632
[2022-04-03 23:14:04] |
edwood - Posts: 3 |
Hello. Today I wanted to connect to the Tenton Futures Order Routing. At step 8, I selected CME Futures Order Routing and Dorman as my Clearing Firm. Then the connection error appeared: No trade accounts assigned Thanks and kind regards Marco |
[2022-04-04 09:13:29] |
Have you contacted Dorman and let them know that you want to use the Teton Order Routing service?
[2024-01-04 16:49:28] |
Sierra_Chart Engineering - Posts: 17179 |
You do need to contact your broker and have them set you up on Teton order routing. Contact them about that. The error you are getting shows that your trading account is not set up on Teton order routing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
