Date/Time: Mon, 10 Mar 2025 17:03:39 +0000
BTC Spot Data
View Count: 652
[2022-04-03 23:11:37]
kwlee - Posts: 4
Does Sierra Chart provide real time Bitcoin Spot data?
[2022-04-04 14:25:37]
Yes data is available from several exchanges. Refer to:
Cryptocurrency / Bitcoin Data and Trading Services
We have temporarily activated your account so you can try the data.
You will need to install the latest version of Sierra Chart:
Software Download
Date Time Of Last Edit: 2022-04-04 14:26:17
[2022-04-04 19:29:38]
kwlee - Posts: 4
Thanks for your information and temporarily active my account.
May I know do I need to pay any data fee, platform fee or exchange fee before I try the BTC Spot data?
[2022-04-04 19:38:21]
kwlee - Posts: 4
Sorry! Three more queries:
1. What data plan I should purchase for BTC Spot? Cannot find it from the page.
2. Apart from BTC, does it provide other crypto Spot data likes ETH?
3. Is Sierra Chart able to connect to Binance exchange to place order from Sierra Chart directly?
[2022-04-04 21:31:58]
John - SC Support - Posts: 38541
There is nothing more you need to do in order to access the Cryptocurrency data. Refer to the information here on how to do this:
Once your current package ends, you will need to select a package for renewal, but the Cryptocurrency data is available at no cost with all Sierra Chart packages.
1. As noted above, you do not need anything special to get the Cryptocurrency data available from several sources.
2. Yes.
3. No, we do not have a connection to Binance for trading, only for data.
[2022-04-05 03:38:55]
kwlee - Posts: 4
Thanks for you help. I have successfully tried to get the Crypto data.
May I check what kind of plan I need to subscribe if I only want to get Crypto data? It looks the payment model is quite complex.
Is it only subscribe "5 - Advanced - 36 USD / Month"? Or select "3 - Standard - 26 USD / Month" is okay?
[2022-04-05 11:12:54]
This will be all you need:
As long as you do not need TPO Profile Charts or Numbers Bars. More information:
Description of Service Packages and Pricing
