Date/Time: Sat, 26 Sep 2026 18:12:50 +0000
[Locked] - Wrong Menu
View Count: 1263
[2022-04-03 21:53:18]
Technical - Posts: 158
How can I configure the newest version of Sierra Chart to default back to the old menu style?
See enclosed.
imageWrong Menu.png / V - Attached On 2022-04-03 21:52:38 UTC - Size: 387.88 KB - 287 views
[2022-04-04 15:37:45]
John - SC Support - Posts: 48028
You can not. The new style is what we are changing to. Refer to the following:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#NewChartSettingsWindow
We see that you called out the chart references in particular. We will make sure that is taken care of so you have a way to see that information.
[2022-04-04 15:58:57]
I think I understand why you might have discounted the older style. The problem is your large users base has adapted to the quirks and now, by fiat, we must all uproot and relearn the familiar menus.
Respectfully, this was not an improvement. Menu options would be an improvement, mandates will raise a storm of protest.
[2022-04-04 16:19:09]
For additional information, refer to:
https://www.sierrachart.com/SupportBoard.php?PostID=301755#P301755
[2022-04-04 22:50:56]
Note that the Chart References are in the Title Bar of the Chart Settings in the latest Pre-Release. If you update to that version you will have that functionality.
