Date/Time: Mon, 10 Mar 2025 16:11:37 +0000
Global Settings - Chart Header
View Count: 477
[2022-04-03 16:52:27] |
nicktrader - Posts: 744 |
In some cases I'd like to switch off the chart header (and later on). Is there a way? Many thanks |
[2022-04-03 18:09:03] |
Yes refer to: Hiding Study and Main Price Graph Names and Values from the Values Windows and Region Data Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
